replacing my ignition switch and I got the gearing off. I have tried to move the gear in the switch several times trying to find the sweet spot but I cant find it. my son moved the gear on the old switch so I cant compare it to that one. so far every position I have tried wont allow the key to be removed. I have to hit the release button to move the key and remove it. any suggestions.
Almost local. We may have a new recruit for our
I should have mentioned that. If there's no power, the key cylinder does not release it. Once you hook your battery back up, it should be fine.
