possible problem after I replaced blower motor
98tsiawd
I replaced my blower motor and it works on all speeds, however I don't get a lot of air coming through the vents on the dash, I get lots of air through the floor vents and defrost vents, could this be a new problem?
Thanks for the help
Classic failed recalibration of the airflow mode actuator. Assume you pulled the battery cable for safety when you did the blower work?
Anyway - plenty of threads on it you can find in a search. There is a fuse-pull reset process that works for some owners. Otherwise, you have to replace the mode actuator.
When mine failed (because I had disconnected the battery), I was able to get them to reset by again disconnecting the battery. I had to do it three, or four, times (changing the position of the controls on the dash) before it reset. Pulling the fuses, as the Roadie suggested, will also disconnect the power to the HVAC unit.
the roadie said:
Discovering WHICH is the right fuse is left as an exercise for the student. :wink:
We'll change your handle to "the professor" :wink:
sklimek1
