Removing C Clip Cant get axle in far enough see pictures
talons24
McLean
I have n 05 avalanche and I would guess it has a locker as it has a plate (See pictures) between the axles and spider gears. How does that plate come out as it doesnt appear I can get the axle in far enough to remove the c clips The Clip on the right, with the magnet attached is close, the left side isnt even close. I am guessing it is hitting the plate. Thanks1.jpg
Welcome to GMT Nation...
Visit THIS Thread... and View Posts #19, #21, #23 and #31 In Particular... BUT reading this ENTIRE Thread will be worth your time absorbing everything else here, as well:
Reactions: talons24
Maybe the spider gears have some wear and moving inwards with the axles. Try pushing them back out while also pushing the axles in.
Reactions: talons24
I know I had to persuade the axles in with a dead blow hammer. I also have a G80 axle.
Just took that dead blow hammer, and hit the end of the axle 3 times. That pushed it in far enough.
oelarse
