pmsmith2032
I need to replace the radiator (leaking) on my 2005 GMC Envoy and am wondering if I should replace the water pump at the same time. The Envoy has approximately 150k miles in it and the water pump has never been replaced. There aren't any cooling problems except for it overheating once about a month ago. When it did overheat I had sat in a parking lot for 15 minutes or so with the air on, drove home for 25 minutes in stop and go traffic, and then turned it off for 15 minutes or so. After driving again for 5 minutes (low speeds under 25 MPH) it overheated. Thanks!
