Hi all did and oil change on the rainier this morning and when I went to check oil life / reset oil life the information center is completely dead none of the steering wheel buttons bring it to life cant get mpg odometer nothing . the other buttons on the steering wheel work so I doubt its the clock spring all gauges work correctly nothing weird is going on .
Is this an ignition switch failure ? I tried replacing the ignition switch last year with a standard brand switch and it never worked right so i put the oem one back in .
I did the switch because i kept getting a stabltrak warning but there was never any codes and it worked normal.
BUT the chances that all switches are "broke" is slim so its either the common ground (point) which the switches are sending to the instrument panel OR the connector just after the clock spring. It can be checked with a meter to see if a ground shows up with the button depression.
