An 2007 trailblazer I'm having an issue with. It needs idle reset and crankshaft relearn My friend bought it from an auction. When I looked under the hood the PCM and throttle body had been replaced with brand new from previous owner. I knew this would be a problem. Previous mechanics also went through the Underwood wiring. I flashed the computer and still no change. There is an aftermarket radio installed but I removed the fuse. I have an code for the air pump as well. It has a bad misfire seems like. I can't get it to idle relearn to do an crankshaft relearn. May be the wiring some where because now another throttle body code has come up alongside the idle relearn. Also is this an factory plug?
