tragicride
- Joined
- Sep 8, 2013
- Posts
- 21
A couple months ago i noticed a problem with my engine wanting to rev a little high.....ruled that out as a clutch-fan...... then my ignition cylinder went out, couldn't get it fixed for 2 days, when i did get it fixed then this clusterF$%&ck of a problem happen. ( while it was down for 2 days ) backed out of the drive way ( did fine in reverse ) put it in drive and had to put the pedal to floor to get any kind of speed..... so when putting it through the gears manually i then found that it wasn't going into 1st. would hardly move. go through the gears and it still takes to much to move it in any gear, ( shifting late with speed ) but it also seems its not getting enough RPM's to change gears,... at first i thought it was a catalytic converter so i punched the guts out of it and that didn't do it so now im thinking it may be shift solenoid A or shift solenoid B. ........ any help please ? i cant afford to take it to the shop so i have to do this myself
