Ashtonross
Please help I recently purchased this truck after my last was totaled the truck has been airbagged an has some wiring messed with. it ran perfect for two weeks an then randomly started idling really rough wanting to die out. I’ve replaced the fuel pump, spark plugs, starter, positive and negative wires from battery, new MAP sensor an the oil pressure sensor it’s throwing po106 po507 po573 po2119 but when I clear them the truck won’t start unless I spray starting fluid. It gets enough fuel pressure an I’m checking for vacuum leak tmr anyone have anything to add? It would be much appreciated
