EXT Blazing
- Joined
- Aug 15, 2012
- Posts
- 8
hi i'm having a problem with my abs and brake light, they keep coming on and off with audible chime while driving, this either happens every few seconds or minutes or sometimes it just stays on for the whole the day with just the chime going off once a while, yet the abs and brakes work perfectly fine even when the lights are one i have checked the fluid level and cleaned up the ground under drivers door, and the problem still persists, is there a second ground for ebcm somewhere?
i went to 2 different shops trying to pull codes and both of them couldn't get anything, one of them had snap on scanner and another gm tech 2, one mechanic said theres a short somewhere in the system causing it
also the thing is when ever i connect trailer to the car the lights go off and never come on, until the next start cycle after the trailer has been disconnected
