I can't find anyone with the climate control AC system to ask about this. In the winter once the engine reaches normal operating temp the HVAC system will bring the fan speed to maximum then taper off as it should. Conversely, on a 90 degree day like today, the system will not being the fan speed to maximum. My experience has only been with Ford systems and they operate that last way plus at either cold or hot extreme settings the blower motor will run continuously on max speed. Is this normal for a GM or could there be a failed sensor? Thank you.
