After replacing thermostat and water pump and putting all back together battery light came on. In order to replace thermostat, I removed the alternator, but kept the wiring connected. I was careful when moving alternator as to not mess up connections. The battery was not connected through all of this. After reassembly, I read the voltage with car running and it showed 14.5 V. After test driving, the voltage to at the battery showed 14.1 V. I checked resistance in the wire from alternator to battery and it showed good. Good news is no leaks and grinding sounds are gone. Can the alternator be removed without removing fan and shroud? What to check next?
