Escapepilot
- Joined
- Sep 21, 2014
- Posts
- 35
Changed the rear end fluid last night after the break in period and noticed my left rear trailing arm is bent. I have no idea when it happened. I don't recall it being that way before I had the gears changed, but I also had the tire/brake off to adjust the e-brake last week and didn't notice it then. Anyway, anyone have one they aren't using and would sell/donate to the cause? Are the TB and TB EXT trailing arms the same?
Second, all of the bolts were tight on the diff cover, but when torquing down to 24 ft/lbs, one just wouldn't torque. I haven't removed it to check the bolt, but assuming the bolt is ok and that the problem is w/ the threads in the housing, what are my cheap options? Helicoil?? It's one of the two bolts next to the one at 6 o'clock.
