OE calipers, yes. What're the Callahan and Brake motive ones that come powder coated red?littleblazer said:You still running the aluminum calipers? I think oem is aluminum.
Steel is better, less flex. I'd imagine after market is steel like the ext brakes. Edit: SS may be steel, not sure on ext.Capote said:OE calipers, yes. What're the Callahan and Brake motive ones that come powder coated red?
I'd have to repaint these ones, I was also thinking a polished look. Can't go wrong with that. Maybe add a bowtie somehow?littleblazer said:Steel is better, less flex. I'd imagine after market is steel like the ext brakes. Edit: SS may be steel, not sure on ext.
I was thinking, and don't know if it's possible, but you could clean up the metal and get it to that brushed look like those rims you posted up, that would match nice. If you go that route.
Etch it in with a dremel and accent it red?Capote said:I'd have to repaint these ones, I was also thinking a polished look. Can't go wrong with that. Maybe add a bowtie somehow?
? Extension cord? I'm really confused.Capote said:I don't remove my calipers from the brake lines when I paint them, unbolt them, sit them on bucket and paint them that way
I'm saying I don't remove the caliper completely. I don't have a long enough extension cord lol. I wouldn't sit outside anyway to etch anything. Plus I would mess it up I betlittleblazer said:? Extension cord? I'm really confused.
Kinda what I thought. It's all straight lines. Have Brandon make a chevy die inverted and then use a dremel to to do it. Or just get decals...Capote said:I'm saying I don't remove the caliper completely. I don't have a long enough extension cord lol. I wouldn't sit outside anyway to etch anything. Plus I would mess it up I bet
Would probably go the tiny decal route, paint over it and then remove it, revealing the colorlittleblazer said:Kinda what I thought. It's all straight lines. Have Brandon make a chevy die inverted and then use a dremel to to do it. Or just get decals...
Good Work Brother!!Capote said:A female chain smoker who's a slob is the culprit I'm sure of it:
IMG_20150904_133840.jpg![]()
Ima need that battery for my keyless entry remote
My kitchen only functions as a workshop:
IMG_20150904_135958.jpg![]()
It should since you are single![]()
Thanks bud, means a lot coming from yourself [emoji4]BlazingTrails said:Good Work Brother!!
Thanks buddy, put a lot of work in recently. The car show was fun, just not as big a turnout because of the rain. Mostly modern muscle and import tuners were there. I was bummed down at first since nobody was checking my TB out. But the first guy that walked up with his son was impressed with everything I did. He thought it was an SS at first until I explained not-so. Then after that I popped up my hood, put my lights and strobes on, that grabbed people's attention. Pretty much got asked if it was an SS for every person's first question that took a look at my rig, even the judges. Looking forward to getting a chance to do another one.SnowBlazer said:Man, that shit looks nice as fuck. How'd the car show go?
Yes I too hate the hood prop, so old school nowadays it seems. I would love a pair of those, would further improve the look when the hood is up.dmanns67 said:You could definitely use some RedLine Tuning hood struts. Get rid of the ugly prop
Awesome work though. You have completed a ton of mods since getting home.
Hmm I'll take that into consideration Kyle, thanks [emoji106]HARDTRAILZ said:I had a TB with both and the struts sucked. two things to be in the way and did not lift as high. They definitely went with the one i sold.
Prop has never gotten in the way, even when me and Brandon changed out my lifters and cleaned everything under there. How much lower do those struts hold up the hood? Because the prop keeps it at a perfect angle, especially with my rig being so lowHARDTRAILZ said:I like the prop...you can use something else to prop up the hood if it is in your way in the front of the motor really easy, but you can't move the struts when they are in your way working from either side.
Ahh that makes senseBlckshdw said:It was probably setup that way for some ideal amount of lift strength, vs ease of closing the hood. That's my guess. I would assume the further back they are mounted, sure the hood is higher, but there will be more upward force when you try to close the hood. Depending on height and strength, that can become a factor for some.![]()
Yeah, tilt switch tied to a relay, since the current rating of the switch was lower than what the LED strip was gonna pull. A little more research and searching, and I could have found a higher rated one, or if I used less LEDs (why on earth would I do thatCapote said:Carlton, I wanna do under hood lighting like yourself, but not the same setup. Did you use a tilt switch?
)I have no idea how I wanna go about it, I want it to look as clean as possible and not have the strips be so obviousBlckshdw said:Yeah, tilt switch tied to a relay, since the current rating of the switch was lower than what the LED strip was gonna pull. A little more research and searching, and I could have found a higher rated one, or if I used less LEDs (why on earth would I do that)
So instead of on the underside of the hood, have the light down inside the engine bay... I can dig it. Well I do prefer the under hold way man, I just don't know how I'd hide things. Maybe some aesthetic strips of green down in the bay too, but that'd just be for looksBlckshdw said:So instead of on the underside of the hood, have the light down inside the engine bay... I can dig it.
At a couple of car shows we've been to, I saw some rides done up like that. Have the strips on the sides of things, and the light reflects off other parts, so you don't see the LEDs directly. Makes it easier to hide wiring, since it can run on the underside of stuff. As long as they aren't too close to a heat source, they should be OK.
Oooo I like that bud. But it fits, just a gap on top. I'm satisfied lolBoricua SS said:Looks like the crap Lotek pod. But we have no choice since nobody else makes a pod. I bought that pod, hacked it up, fiberglassed it to my OEM A Pillar, bondo'd, sanded, primered, and painted. So now I have an OEM A pillar gauge pod. No overlay or replacement.
Gotta love gauges!![]()
Just spray foam insulate it!Capote said:Oooo I like that bud. But it fits, just a gap on top. I'm satisfied lol
Hell no, need a gap for the wiresSnowBlazer said:Just spray foam insulate it!
