Hi, all. I have a used 2002 Envoy SLE (4.2 I6) that is in great shape, except for no transfer case control (surprise surprise...)
At any rate, I get the classic "lights on control switch light for a few seconds at start up, then turn off, with check 4WD light on dashboard". So, the switch most likely is good, and I've tried the fuse-pull approach to waking up the TCCM with no luck. I'm about to order a TCCM off of eBay, but before I do, I want to confirm the inter-compatibility of the different modules.
Which TCCMs can swap for each other? So far, I have run across several different GM TCCM model numbers, and I read somewhere that there may be as many as 12 different ones. Will any of these work in my 2002 Envoy? Are there particular model numbers to avoid (e.g., the ones that were in the 2002 vehicles?). I can see that there are bits and pieces of information that one can piece together from different posts, but I thought that it would be a good idea to have a single, clearly labeled forum thread about the compatibility of different models of TCCM to put that issue to rest.
Thanks,
-Chris
Thanks,
-Chris
