misterhyde
- Joined
- Oct 14, 2012
- Posts
- 34
Got the '05 in '08 with around 60~65k on it. Jumped right into the online community for the TB's on the OS. Everything with this truck seemed to go wonky after the exhaust manifold cracked and I ran it for about 3 or 4 months in Michigan winter until I got it replaced (with aftermarket). My mechanic (whom has since blown himself up in his garage dropping a gas tank to a suburban/tahoe and past away a few months after due to the burns, but off-topic) said he had trouble with a few bolts, but was able to get them all out. Of course, you can't see the lower bolts
Anyway, even after PCMforless.com PCM tune first, then the Transkit (here) which is this with a corvette servo, I still have harse shifts from in the early ranges (1-2, 2-3) and hesitation starting from a stop (acts like not in gear for a few seconds then grabs and goes).
I was recommended to the tranny shop that did the trans kit and they did not relay that there were any problems with the install. All they do is Tran's by the way.
What is also a nusainse is that it seems to go into 4th (TC lock?) early.
I do now have a BT OBDII module and the Torque Pro app on my phone. Trans temp seems to stay under 200deg F, as I don't keep a close eye on it but wanted to make sure it wasn't too high.
Other things I have done to the truck (in no order, can provide if needed):
Resonator delete
90deg tail pipe
new direct-to-fit cat (thought it would help
new aftermarket exhaust manifold
plugs changed around 100k
new water pump
new cts + tstat
mech fan removed
PCMforless.com PlugnPlay efan kit (temp probe in top water outlet, but going to move to lower soon due to always on)
PCM Tune from PCMforless.com
Secondary air system now completly removed (solenoid removed and port plated recently)
New Variable timing solenoid
new camshaft pos. sensor (recently)
O2 sensors replaced (NTK front, ACdelco rear)
Resonator delete
90deg tail pipe
new water pump
new cts + tstat
mech fan removed
