Electrical issue
slowauto
Driving along, lost gauges, radio, elec.windows. Stopped to check, relay or solenoid noise under hood when key is moved from off to on position. Engine starts no problem. After a lengthy cool down period, everything came back. Happened twice now. Checked owners manual for possible answer and found nothing specifically related to what was going on. Have been replacing control modules on a regular basis. Headlamp and door lock specifically. 265000 miles on an 02 Envoy. Any ideas ??? Have a code scanner but was not with me when failure occurred. Love the new home page. Thanks, Terry
Suspect a loose fastener on the front fuse block megafuse or the red wire power feed to the rear fuse block.
I saw the "mega fuse" in the owners manual. Will check that first thing in the AM. Thank you.
Cleaned connections at mega fuse, fuse was ok, and finally found a "power amplifier" in the under seat fuse block that was bad. Replaced it temporarily with a 30 amp fuse. All problems solved. Have since replaced fuse with a new "amplifier" ,a temp sensitive circuit breaker, of the correct amperage. Life is good !!
Gustavoc100
