sk8ermadre
- Joined
- Apr 20, 2015
- Posts
- 10
Hello all, I have a 2002 GMC Envoy SLT with a Vortec 4.2L, 6-cylinder and the tranny is 4160E. It has about 188,000 miles on it. I recently payed way to much ($3,030.10) at AAMCO in Lancaster, California for them to fix my slipping transmission. I know, I got screwed! It doesn't matter if I got screwed because I am a woman or because I do not understand the inner workings of an engine or transmission. Screwed is screwed any way you look at it and what is done is done. In an attempt to salvage my beloved Envoy I come to you my new acquaintances and 'GMC Gurus'. I have had my SUV back for about 7 days. It does not have any where near the same power that it had before the remanufactured trannny was put it, it does not get up to speed as quick as it used to, it does not seem to shift as smooth as it used too, it is using way to much gas then it should be, it revs up to 4 RPM's and drops down to 2 1/2 RPMs and it deaccelerates going downhill (meaning if I am going 70mph downhill and I take my foot off the gas pedal, the Envoy rapidly slows down 69, 68, 67, 66, 65, 64 rpms and so on). Before I could step on the gas pedal and take my foot off for a bit and continue the same rate of speed until it would very slowly start to go down 69....69.... 68....671/2.....67..... and that would usually be after the road levels off and I am no longer driving downhill. The car also seems to randomly be choking or losing power slightly when I push on the gas peddle usually when going around 50 mph but today on my way home from work it did it at 70mph too. I also have a code that was not on my car before taking it to AAMCO. It is a POO14 code. I think this code is for the Camshaft actuator position and am currently reading what that actually means and the possible causes of it. Now my ABS light is also on as well as my check brake system warning message on the driver's message center behind the steering wheel. Within the last 3 months I have had an oil and filter change and six months ago I had front and rear brake pads changed and rotors turned as well as new rear shocks. About six months ago I also had new spark plugs put in.
*My questions are
-can any of the above mentioned problems be caused by the remanufactured tranny?
-Any suggestions or checks/repairs that I can do myself to further investigate the losing power and acceleration problems?
-Can the Check brake system and ABS light problems cause tranny problems, the POO14 code or any other above mentioned problems.
-Will I screw up anything in the motor driving with the ABS/Check brake system light on until I can save enough money to have the brakes looked at.
P.S. I noticed after crawling under my Envoy that I am completely missing a sway bar link on the drivers side. Can this cause the ABS/check engine light to come on?
Any help would be greatly appreciated
Thank you,
Robyn Patton
*My questions are
Thank you,
Robyn Patton
