Im getting a P0141 code. I have no cat btw a PCM4Less tune with no cat tune. I cut my cat off bought a 3" 17" long pipe from o'reilly's auto for $6.99 and welded it on. now im getting a P0141 code. i have a scantech gauge and i remove the code every time i start the car and drive. I need help plz
After Googling i found
[h=2]Technical Description[/h] O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
[h=2]What does that mean?[/h] This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141. See also: P0135 (Bank 1, Sensor 1).
[h=2]Symptoms[/h] You will likely notice poor fuel economy the illumination of the Check Engine Light.
[h=2]Causes[/h] A code P0141 may mean that one or more of the following has happened:
[h=2]Possible Solutions[/h]
- open or short to ground in the wiring harness
- O2 heater circuit wiring high resistance
- O2 heater element resistance is high
- Internal short or open in the heater element
- Replace oxygen sensor (cannot repair open or short that occurs internally to sensor) (I have a brand new ACDelco O2 installed in the manifold a month or so ago)
- Repair short or open or high resistance in wiring harness or harness connectors (The Manifold Harness was NOT disconnected when doing this weld)
The TB drove like a bat outta hell.
