kickass audio
- Joined
- Aug 25, 2012
- Posts
- 955
Since I recently traded in my 2004 Envoy for a 2014 Silverado I have some parts that I removed from the Envoy prior to the trade in for sale.
1.) Futurevision HID 35w bulb with relay harness, 2 ballasts and 2 bulbs.
The kit will have the 2 35w 4300k bulbs, 2 35w HID ballasts, and one relay wiring harness you use to wire the ballasts directly to the battery and then trigger them on and off by tapping into the OEM fog light wire.
Looking to sell the fog light kit for $80 shipped
2.) A pair of fully assembled and retrofitted Futurevision 50w HID 64mm projectors. These are bi-xenon projectors that are setup so if you have the DRL mod (also better referred as the quad light mod) you can use them for both low and high beam driving. The bulbs are 50w 6000k lights. The kit will contain 2 fully retrofitted headlights with 64mm bi-xenon projectors installed, two independent relay harnesses for redundancy that you hook up the ballasts up to the battery for direct power.
Looking to sell the headlight kit for $200 shipped to the cont. U.S.
