Dear all,
This is my first Post, and I'm looking for some help advise.
I have a 2002 Trailblazer LTZ 4x4 I6, and love the car.
Recently I got the SES light come on and got DTC P1484, and replaced the EV Fan (it had locked) with a 25790869 one. A month after the replacemente we drove the SUV for 200 continous miles, and when heading back home the SES and REP lights came on at the same time when passing a slower moving car and accelerating. I had it scanned and the stored code was P1484. I took it to the dealer and they told me the issue was the thermostat, since they found "low cooling system performance coolant temperature low", so I had the termostat and the temp sensor replaced at the same time (the old t-stat was completely open), with ACDelco parts deleted the code and I was set, or so I thought, after driving a few blocks the SES and REP lights came back, so, back to the dealer, P1484 again, initally they asked, when you replaced the fan, was the PCM flashed? the answer is no, it was once way back in '03, when it got it's firs EV-Fan replacement, but not with this newer one. They, or so they say, swapped the Fan relay with the headlamp one to check and nothing, and also checked the damaged EV Fan harnes TSB, and mention neither is the problem. They tried to flash the PCM and mention the PCM would not take the flash, and they could not get the TB's serial number from it, so they're assuming the PCM is damaged, and mention they are surprised that the vehicle actually runs, since the PCM is damaged. I assumed the PCM entered into "safe mode", but if this were the case the TB would not shift further than third gear and it does, everything appears to run fine, reason for me to be reluctant to buy a PCM and it not be the actual issue, (obviosluy lower gas mileage), SES is on and REP comes on pretty quickly, specially when hitting the gas a bit hard.
Any thoughts?
Does anybody know the difference between the 2 part numbers out there for the PCM 12576463 and 12571178, tey both seem to be replaced by 19210066.
19210066 is 1,000 US dollars to buy in Mexico + labor to install and flash, so my thoughts were to get one from Ebay or a Junkjard, one of the other two I've found for this year model, but, not sure if it the diferent part number actually has a difference, and reflash to my car, if this were possible and the actual issue.
Your thoughts will be highly appreciated, apologize for the long post, but, needed to mention most of the story behind this.
Thanks,
Carlos
Any thoughts?
Thanks,
Carlos
. He then said, he believed the PCM was somehow damaged and tried to reprogram an other module, and this didn't work either, so I asked him, does that mean there's something wrong with the diagnotic port or a harness? and he said that would be very rare, that it's more likely the PCM, since the update to the BCM (module he tried next) goes through it.
