So after driving into work this morning, 15 minute trip, after turning off my 02 Envoy I later realized, from in the office, that my headlights were still on, minutes later. I knew they were set to auto and should have been off, so quickly went out to take a look, sure enough I could not manually turn off the lights with the in cabin switch.
Popped the hood and noticed my fuse box was smoking, removed the covers and found the 46-HDM relay was melting down on the fuse box. I quickly found a pair of pliers and disconnected the battery, but not before some damage was already done:
(I have a few surrounding fuses/relays pulled in this picture to, needed to clean them up from the left over melted plastic)
So my obvious concern is what caused the problem, could it be as simple as a bad relay? I wanted to ask for some advise here, as I do not want to replace the relay and have the same problem again in a day or so. Also, I am not sure if the entire fuse block should be replaced at this time, or if a cleanup job and ensuring the relays seat properly is good enough?
Any advise is appreciated.
It's normally a sign of the forum volunteer's failure when we hear of dealers being the troubleshooters of last resort.
