Hey all, I have searched thru a few posts regarding front calipers stickig and uneven pad wear but I have a issue I cant seem to get resolved. My 02 LS was due for rotors and pads. I swapped them out and all seemed great for about 2k miles than I had my master cylinder fail. Pedal went to the floor and no brakes. I had a new MC put in and about 200 mile later I had the brake pedal go from normal (for a TB at least) to rock hard and the front brakes felt like they were draging. I would release the pedal and the truck would sit there as if the brake were pressed. As I limped the truck home the pedal went back to normal and all was fine. Seeing as I cant live with this I brought the truck in to have a look see and was told my booster was bad. Now after $$$$$$$ installing the booster the pedal is once again hard and the brakes feel as if they are dragging all the time. So intotal I have new rotors,pads, calipers, new, brake lines, new master cylinder, new power booster, and still sticking brakes. If the bleeder is opened the brakes release. Any help would be appreciated otherwise I have a 02 TB for sale..
Forgot to mention, I verified only fronts were dragging by lifting truck and the fronts would not spin freely until bleeder was released.
