rcfiddy1 said:
Thanks anyway. Seems like all info regarding that anti theft says it prevents the ignition key from turning off. I was able to turn off the key and remove it. Which makes me wonder what it could be.
No. The Passlock system doesn't mess with the ignition. The shape of the key itself is supposed to operate the pins in the lock cylinder which allows the cylinder to turn. A worn, damaged, or incorrect key will obviously not place the pins in the proper position. A faulty ignition will obviously have trouble turning, too. Passlock is pretty much just a resistor in the ignition module that presents a part of the security puzzle by minimizing the possibility of hotwiring.
The solenoid described within the ignition's sole purpose is to prevent the car from being turned off with the transmission in anything but Park or Neutral (or maybe just Park). Pretty much it locks the cylinder in place. The mention of this solenoid does not even appear in the shop manual as a possible problem when trying to get the ignition out of OFF. However, it can cause the vehicle to be unable to get the key into the OFF position.
There's three causes of this:
-Damaged, worn, or incorrect key. Obviously you have the correct key, but is it damaged or worn down? The key should look silver-colored, the sides of the blade with the "hills" will wear that coating off over time exposing a yellowish-colored metal underneath - this is your first indication that the key isn't in new condition anymore, but not an indicator of actual failure. You can sometimes compare the two sides of the blade, they should be EXACTLY identical, if they're out of shape in comparison to each other it's definitely a worn key.
-Faulty or damaged lock cylinder. This happens a lot, actually. Or at least there's plenty of threads from newcomers, and mentionings-in-passing from long-timers, about replacement. In fact there's posts recommending a spare cylinder be kept on hand just in case.
-Loose ignition lock cylinder case assembly. Don't see a lot of mention of this, but literally you just tighten up some fasteners if they're a bit loosy-goosy, and it sometimes fixes the problem if the above two are not a problem.
