I suggest AcDelco or GM only when it comes to electronics... some members have reported auto zones coils to be delphis, of course who knows if the guts actually fall under Delphi's guidelines....you can buy a set of 6 AcDelcis from ebay for $225.00.... I just bought some last week for $213.00, unfortunately engine took a dump on Monday, so will wait to install them...2x1968muscle said:Hello,
just limped home with what turned out to be P0301 code
-swapped out coil number one and i'm back in business.
After reading the posts above I have decided to replace the spark plugs to eliminate that from the cause list.
My question is about the coils. I had one of the stock ones fail in the summer of 2013 and I replaced all 6 with Standard Motor Products coils. Since then I have had 3 of the Standard Motor Coils go bad on me and I have limped home to re-install one of my "spare" Delco coils.
Like many of the other parts on these trucks, should I only be putting Delco coils on this engine? or is there an acceptable quality brand out there that will last more than a year.
Thanks for the help, it's really appreciated.
2003 Trailblazer EXT 4.2 with 148000 kms
Hi and thanks for the suggestion. I might just have a look at Ebay.KNBlazer said:I suggest AcDelco or GM only when it comes to electronics... some members have reported auto zones coils to be delphis, of course who knows if the guts actually fall under Delphi's guidelines....you can buy a set of 6 AcDelcis from ebay for $225.00.... I just bought some last week for $213.00, unfortunately engine took a dump on Monday, so will wait to install them...
Your coils didn't come with a LLW? you could return them and upgrade to maybe Borg Warner..
