chopper320
- Joined
- Apr 23, 2014
- Posts
- 25
I have the p0410 code on my 04 trailblazer and my wife's 05 trailblazer. I'm trying to troubleshot mine currently. I took the hose off of the solenoid valve and did not hear the exhaust noise. Also did not get sucking or blowing from the 2 hoses.
I did find the # 56 fuse was blown but the other fuse was fine. I replaced the # 56 fuse but it didn't fix the solenoid valve or the hoses. Would it be safe to assume that the solenoid valve AND the air pump are bad at this point?
I can use a multimeter but I don't know how to run 12 v thru the air pump or relay to test those.
Thanks
Thanks
