Up And Down
- Joined
- Oct 25, 2012
- Posts
- 126
The power steering cooler is leaking on my 05 TB. Reading online, some people say the unit can be removed without taking off the bumper cover. Others say this is only possible on the Envoy. Has anyone here done this job on a TrailBlazer and, if so, is the front bumper cover removal necessary? Is there any way to get at the mounting bolts without taking the bumper cover off? For those that don't know, the factory cooler is steel and is a common issue for leaks. Dorman makes a direct replacement that is aluminum. Thanks in advance for all help.
but I learn a lot out there that might help you guys. Have you ever felt your bypass hose to see if it's getting hot driving around town?
