Hi all I’m new here and have a quick question. I want to change my lower control arm tomorrow along with the inner and outer tie rod ends, anyway I’m assuming I have to take the axel off and the inner tie rod on the other side I took off with a pipe wrench (which I know isn’t perfect but it worked lol) anyway I was wondering if anyone knew what the size socket I need to take the bolt off for the axel and what size the bolts where (the big ones) that hold the lower control arm on? I just want to make sure I have what I need before I rip it all apart and go ah sh$& I need______! Btw I’m replacing the whole arm not pressing new bushings in. Thanks for all the help
...as the bracket went backwards due to insufficient bolt torque.
