Replace rubber brake lines, yea or nay?
C0267 is pretty definitive if it's been diagnosed properly to rule out a wiring or power issue to the module. If the valve is stuck open, I could see that causing the issues.
Hmm. I'll take a close look at any connectors/wiring/grounds I can access before buying anything. Guess I'll pull and inspect the ABS fuse too.
Just seems weird that this pops up after changing some brake parts. Maybe the first fluid flush was enough to cause something already on the verge of failure to give up? Dunno.
Should also mention I've never gotten an ABS light.
Turning this over in my head some more and I'm wondering if it's actually the pump that's bad.
I was wondering why this issue would suddenly present after replacing those brake parts, seemingly out of the blue. Here's the thing - I absolutely neglected the brake fluid on this. When I went to swap the master cylinder, I saw that my old one was full of black gunk that caked the inside of the reservoir. Probably seals somewhere breaking down.
Anyway, I'm thinking that maybe when I did the fluid flush it pushed a bunch of gunk that was sitting in the lines into the pump/valves which played havoc with it. I'm not at all certain of this, and I have only the faintest grasp of ABS system design and operation, but it's something to consider.
Which leads me to my next point - I still don't quite get how even a stuck open valve would cause such a soft pedal and poor brake response. You'd think you'd still be able to max out the hydraulic pressure and lock the brakes up, just maybe with a bit more pedal travel? Don't know, but the valve explanation isn't making sense to me just yet. Not saying it's wrong, just can't wrap my head around it.
Like ok, maybe the fluid bypasses the valve when it shouldn't, but so what? It's a closed system, it can't go anywhere, right? It's not like this opened up a giant, empty cavity for it to flow into, and even if it did that would imply the presence of air in the system as the cavity would have otherwise filled with fluid by now. And if said cavity is filled with fluid, then hydraulic pressure should have been restored and the system would just act like a car without ABS? I know I'm missing something but this just isn't making sense.
  • Wow
Reactions: movietvet
Yep since the code specifically says that the pump motor circuit is open. Again, barring any wiring or power issues to it (fuse/ground), the module is trying to power the pump and getting nothing.
It's quite possible junk got to the motor and when it tried to activate, it burned out because it was stuck.
If your pedal is firm enough (02-05 had soft-ish pedals due to the aluminum front calipers), then sure you can drive it without ABS. But if air got into it and the pedal is soft, then you will have to replace it.
I don't know anything about the abs operation but it seems rather "simple" in terms of "outward" electronics. The first concern would be the lack of indicator light on the dash for the fault code. Do you see the abs light during the "all lights" check with key on? As mentioned, have you checked the the voltage and ground conditions going into ebcm? It does not sound good for the ebcm module, if its not setting the indicator light?
Brake fluid flush is one of the most overlooked maintenance services. It is important, in an instance like this, especially if you live in a mountainous area.
I'll still check everything I can to try ruling out the EBCM, but I'm very suspicious about the condition of the pump. Just doesn't make sense to me that an electrical fault like this would pop up out of nowhere and coincidentally right after a fluid flush.
And of course the pump is the one mechanical part on this thing you can't buy new or remanufactured. Guess I'll pull it off and see how serviceable it is, but I won't get my hopes up.
No can do on driving without ABS, my pedal is still soft as a kitten and the vehicle has maybe half the brake force it should have. FWIW, my mechanic triggered the ABS with his scanner and said he could hear the pump running. If the fault is somewhere inside the pump assembly, I'm thinking the motor is fine and there's gunk jamming up valves or other little passages inside it.
Can
does the light work? Based on what the garage guys did commanding the motor to run, it would appear to point at the EBCM module as having an issue and not fully operating valves. Check the voltage going in on the c2 connector along with the grounds. Specifically, disconnect the positive and negative as the battery. Disconnect the c2 connector at the ebcm. Do a resistance measurement at the positive disconnected cable to the battery pin on the c2 connector. Likewise for ground pin. Both should read very very low (ensure that you understand what your meter "zero calibration" is for the resistance function).
Having said this, if you have never seen an ABS light before this and thus never pulled codes, how would you know that the system is "in trouble". Was the ABS recently "firing" during some brake sequence?
ADDED: NOTE to check the powering connection (from positive battery to pin in the ECBM connector), the key must be set to "RUN".
Can
I'll check today, but regarding your second question I'm just trying to chase down what's causing my soft pedal and lack of brake engagement. If the ABS system is part of that, so be it. I never really had trouble with it prior to doing this brake job but my mechanic pulled codes for the ABS so 🤷‍♂️
What is the c2 connector? Based off pics online I see three different connectors going to the EBCM, which one am I looking for?
I understand.... but you also made comments about "I'll still check everything I can to try ruling out the EBCM". I am trying to help you do that. As I mentioned and you stated, that the mechanic was able to operate the motor, so it is unlikely that the motor itself is bad (its not 100% guaranteed because no pressures were measured... but likely the motor is operational).
As for the connector, I was looking at the schematics and that what is stated... I ain't an expert on GM designations.... :-) There is a C1 connector identified going to the motor (it appears to have only 2 wires). Posting a picture of your EBCM / connection might help.
Further, as to whether the ABS is your source of the "soft pedal", the problem might be that prior to your work effort, IF you didn't know you had some codes and / or dash light, then you don't really know what the state of the EBCM was and therefore it is possible that air might have gotten into the unit. As a result, ABS activation is probably required to get rid of that air. Of course, just guess from the description. It is likely that only a tech2 will ultimately resolve questions.... that and suggested tests and checks.
Update - ABS light is functional. I pulled the ABS fuse both to check the light and to see if it changed the pedal feel with no power going to the EBCM. The ABS light illuminated and the "Service Brake System" message appeared on the dash. No change in pedal feel or brake behavior was noticed.
I also checked continuity on the ABS fuse and it appears to be good.
Pulled the pump and EBCM off the car. I don't see anything that would raise suspicion. Connector pins all look perfect, there has been zero intrusion of water or debris into any of the electrical connectors. Will try continuity testing once it's figured out where exactly I need to probe.
Pic of the pulled EBCM below.
The female connector end on the right is occupied by a male connector attached to the pump motor, which has only two wires running out of it. It seems its only purpose is to allow the EBCM to supply power to the pump when it commands it on.
The other two female connector ends on the left are occupied by male connectors running out of the wiring harness on the vehicle. I assume the one with a bunch of little pins is for data, and the other with two big pins is for power.
Regarding the pump motor, I pulled it off the valve block and there is no way whatsoever for brake fluid to enter the motor. It is completely isolated and there is seemingly no reason whatsoever for it to care at all about whatever is going on in the valve block. It isn't even mechanically connected to it, it uses what looks like a cam to actuate two spring loaded plunger things inside the block.
Pump motor cam pictured below, followed by where it mates to the block. You can see the two spring loaded plunger things that are responsible for the marks on the motor. The plungers move freely, they're not locked up.
The valves are, unfortunately, unserviceable, at least not without a lot of effort and something akin to a small machine shop. They are pressed into the block and appear to have somehow been staked in place using a metal dowel or something, hard to tell. Tried actuating them with a strong magnet and got an audible click out of all six, but I can't say what that click was. None sounded significantly different from the others.
Point being I have nothing resembling an answer yet.
which fuse number?
ADDED: My read of things is that pulling the / a fuse does not necessarily mean that the EBCM is functioning in terms of warnings as the warning could be generated elsewhere because another module (BCM) didn't receive an appropriate message because of lack of power. Perhaps @TJBaker57 might have comment. Based on reads, the EBCM should light the indicators if the coding has been set. Further, it does an initialization check every key run and speed (4 mph+). You would likely need a tech2 (or equivalent) to manually operate valves to cause fluid flow changes to check which / if any valves cause pedal changes. Can you phone a "tech2 friend"... :-)
which fuse number?
ADDED: My read of things is that pulling the / a fuse does not necessarily mean that the EBCM is functioning in terms of warnings as the warning could be generated elsewhere because another module (BCM) didn't receive an appropriate message because of lack of power. Perhaps TJBaker57 might have comment. Based on reads, the EBCM should light the indicators if the coding has been set. Further, it does an initialization check every key run and speed (4 mph+). You would likely need a tech2 (or equivalent) to manually operate valves to cause fluid flow changes to check which / if any valves cause pedal changes. Can you phone a "tech2 friend"... :-)
Fuse 33.
I don't know anyone with a Tech2. Might have to try buying one of the knock-offs I guess. Have I mentioned how much this sucks yet? :Banghead:
  • Wow
ABS motor is confirmed GOOD. Used a couple solid copper wires as leads, plugged them into its connector, and tapped them to the terminals of a 9.6v drill battery.
I'm aware that's not ideal but I connected the motor to power for less than 2 seconds and only did this 3 or 4 times to confirm function. Motor spins well, no weird noises heard, plenty of torque.
Fuse 33.
Interesting as fuse 33 is the powering for the motor and not necessarily the main power for the EBCM which appears to be 51 so the EBCM appears to be setting the light as opposed to the BCM that I had suggested.
Of course, it would be nice if you could read brake codes.... thus the test would be reset the codes, then pull 33 and read the codes again to see which ones pop up or are different.
Question: when the mechanic said "no air in the system"... how did he determine that? Did he do a ABS activate bleed?
Actually it turns out I can read brake codes, I just never thought to since it didn't throw a dash light. I poked around on my scanner when I had the fuse out and found where I could read them. Pulling fuse 33 DID set the ABS dash light (and it went away when it was put back), but I have never seen it come on before, not even once.
Also, it appears, via my admittedly limited testing, that the valve body is fine. I get clicks consistently when applying a magnet to them and was even able to confirm a change in flow direction by blowing compressed air through the fluid inlet/outlet holes.
I looked close and did get some gunky fluid coming out, so my flush did not remove all the old fluid from the valve body, for whatever that's worth.
ok... so then are the codes the same with fuse in versus fuse out? Of course, the matter of "code reset" has to be considered which might not be within your reader capability.
I wonder if that shop actually read an old/historical code rather than an active one? He even said that he was able to activate the motor but it had a code saying that it was open? Since you didn't have the ABS light on and it's confirmed it works, maybe we're chasing a red herring.
I'm still convinced you still have air in the ABS. Or you're interpreting the soft pedal of this era truck with the aluminum calipers as too soft. But you are saying that your braking performance is lacking so ??? Maybe taking it to a dealer to have them bled, specifying that the MC was replaced and the ABS needs to be bled, might resolve it.
I wonder if @TJBaker57 might have a trick up his sleeve in using an ELM327 and a command through it that can activate the ABS for bleeding. There are some cheaper scanners out there that can do this.
Actually, looking over the Autel readout again, it does say Status: History for all the codes. Of course there's no context or timestamps, so I have no idea when it ever threw those codes.
I mean there's definitely air in the ABS now that I went and blew air through the valve body lol.
I'll roll this around in my head during the week but at this point I'm thinking - reassemble ABS module/valve body, double check master cylinder for air, try to flush air introduced into lines when the valve body was removed, and then see how to go about performing a proper ABS bleed.
The only other thing I can think of is that a seal in one or both of the front calipers is bad and finally gave up when I pushed the pistons in to fit new pads. Note that the pistons were pushed in with the calipers separated from the brake lines, so there shouldn't be any issues with pushing stuff back up the lines. You'd think I see fluid leaks by now if this was the case but hey, weird stuff happens sometimes.
The pedal definitely does not feel the way it should. It is significantly softer than it was prior to doing this and brake engagement is noticeably worse, no doubt about it. Mechanic also noted the soft pedal. Should have recorded a video of the behavior, even without being able to feel it you'd know something was wrong just watching how easy it is to move the pedal.
Doing some more reading online and finally found something that matches the description of my problem exactly - It appears that a stuck open dump valve in the ABS valve body can cause a soft pedal that goes to the floor with brake engagement near the end of the pedal stroke while still allowing the brakes to release. That is the exact issue I was having.
That's not to say that's what happened here for sure, but the symptom description is dead on. I'm fairly certain the o-rings used in the valve body are EPDM rubber, that's the only rubber typically advertised as safe for long term exposure to brake fluid. If I can find an EPDM safe cleaner I might let the valve body sit in a bath of it in an ultrasonic cleaner just for the heck of it.
I guess the question would be: what did the mechanic do when he tested for "air in the system"? Did he or was able to cause operation of valves which should have been one of the tests of the system especially the isolation / dump valve. Anyway, hopefully you can "free things up". It doesn't appear that you are getting other codes that point to electrical issues with some of the circuits.... although it still seems rather strange that there is no dash lights set for the issue... to me that points at some internal control function issues.
I wouldn't muck around with the internals of the valve body. With something as critical as the brakes, I wouldn't want them to fail on me for some unknown o-ring. I'd replace it either with a new or used one. Haven't heard of any of these failing before (the valve block, not the module). RA doesn't seem to have any and GM has it discontinued. O'Reilly's seems to have them from ACDelco. Part number 89027155
I'd even feel better using a used one.
Edit: Checked some more and Summit Racing lists it as not available so I would assume the same from O'Reilly's. Used may be the only way to go.
Yeah I had looked already and all you can buy are used ones off a parts car. Annoying that these aren't serviceable.
I'll open up the control module and take a look at the board, only other thing I can think of that would have an obvious issue. Also trying to hunt down the cheapest scanner that can perform some kind of ABS activation. Foxwell NT630 Pro looking like a decent candidate and their site claims it has full ABS functionality for my TB but I'll email and confirm.
Enter when the problem is electrical and not mechanical meme here. :cry:
Update - Got my new diagnostic scanner and performed multiple automated ABS bleeds. Between each ABS bleed I got out and bled the brakes using my one-way bleed kit. Also bled the master cylinder again just to be sure, got zero air out of it.
While performing the ABS bleeds did push some air out of the lines, pedal feel has still not significantly improved. I should also note that I cleared the DTCs for the 4WAL 3 sensor (read: the ABS system) and after that, no DTCs were thrown by running an ABS bleed, though I don't know all the conditions necessary to set a code.
I am officially out of ideas. There is nothing left to test as far as I'm aware, and I still don't have any fluid loss/drips/runs. Below are videos of the pedal behavior, post ABS bleeds, with the vehicle on and off. The pedal is significantly stiffer with the vehicle off but can still go pretty much all the way to the floor. I know you can't actually feel the pedal through a video, but this is the best I can do.
Engine ON video.
Engine OFF video.
Figured I'd post a recap just so no one gets lost -
  • The brake booster, master cylinder, and all four rubber lines connecting to the calipers were swapped with new parts. The front rotors, front pads, front caliper mounting brackets, and all 8 caliper slide pin boots were also replaced.
  • The master cylinder was bench bled. I also plug tested it in the vehicle and got a hard pedal that did NOT sink. I bled the master cylinder again inside the vehicle and got no air out of the lines.
  • The master cylinder is NEW, and it is an OEM ACDelco part. I would be very surprised if any of the seals were damaged, even with fully cycling the piston. There should be no corrosion or roughness in the bore that would damage any seals. And again, the plug test was good.
  • I have attempted multiple brake bleeds after swapping these parts, with none of them improving the pedal feel.
  • I now have a diagnostic scanner that can control the ABS module and perform an automated brake bleed. I have performed at least 4 automated ABS bleeds, bleeding at the calipers in between each bleed, with minimal improvement in pedal feel.
  • I have bled more than two gallons of brake fluid through the system trying to make the pedal stiff.
  • I see no drips or runs of brake fluid anywhere and my master cylinder reservoir does not lose fluid even when sitting for a week or more. I can pump the pedal numerous times without losing fluid.
The only thing I can think of at this point is that there is either some issue with the ABS assembly that isn't making itself obvious, or one or more caliper piston seals are damaged, but in some bizarre way that doesn't make it obvious. I cannot puzzle out any other explanation for this behavior.
There is ONE more possibility: the rubber line that goes onto the differential and splits to the two rear calipers. Inspect it and pinch it off to see if there is much of an improvement.
To rule out the calipers themselves you could use a hose pincher at each caliper one at a time and see how much it improves. It could be a caliper that retracts too much on pedal release.
Sitting here in a hospital gives me much time to think of things 😁
Ouch. Hope you're ok.
Don't know if this means anything but one thing I noticed is when I bleed the brakes, the pedal is noticeably stiffer when bleeding the rears vs when bleeding the fronts. I'll think about pinching off the lines by the master cylinder but they might be PTFE lines since they're braided stainless on the outside, which means pinching them is probably a bad idea.
ETA: I wonder if pulling one line off the master cylinder and plugging the port would do the same thing as pinching the line.
I'd pinch off the lines at the calipers, not the braided ones.
Update - I tried a pressure bleed, no luck. I got no air whatsoever coming out of any of the four calipers.
Tried using my scanner to diagnose whether the ABS valve body is bad, but not sure how to interpret results.
These units have six valves: Left front isolation valve, left front dump valve / Right front isolation valve, right front dump valve / Rear isolation valve, rear dump valve.
I followed someone else's advice to test the valves. Isolation valve test should reveal a higher pedal if one of them is bad, while the dump valves should all drop the pedal when activated.
All my dump valves will drop the pedal, but I found no difference in pedal height or feel between any of the isolation valves. Something else happened, the meaning of which is not apparent to me - If I depress the pedal about halfway and then activate a front isolation valve, the valve command will be forced off, the pedal drops, and then the ABS light illuminates and I lose control over the valves. This condition could only be reset by turning the vehicle off/on or by performing an automated ABS bleed.
Finally, I have a video of pedal behavior during an automated ABS bleed. I doubt this will tell anyone anything, but you do get to see how far down the pedal goes.
Problem remains unsolved. Not sure where to go from here other than installing a different ABS valve body.
At this point, I would have just replaced the ABS with one from a junker. Except for the electronic module, I don't recall anyone talk about the valves failing.
The fact that you get the ABS light while you are testing and lose control tells me it's bad. I'd try it on mine but it's an 07 with a four channel system. 02 is three channels.
When you do this and get the light, can you go back and scan for codes? I'll bet it comes back to the same code as before.
huntylterer
