NEED HELP Replacing the Panhard bar
Ric_Whit
Hi all,
I’m about to replace the rear upper and lower control arm of my 2002 Trailblazer LT 2WD 4.2L.
The problem is the panhard bar (Parts # 15069843 for 2002-2004 & Parts # 15223490 for 2005-UP 4.2L, 5.3L Eng.) are discontinue.
Now here is my question to any one on here that may have done it or have replace their driveline for the SS 6.0L Eng.
Will the panhard bar Parts # 15241319 for 2005-UP 6.0L Eng fit my 2002 2WD 4.2L Trailblazer????
You can buy aftermarket trailing arms and panhard.
What's wrong with your existing one? I had the factory one the whole life of the vehicle, never had an issue with it.
I did have to replace both upper trailing arms. Lowers were fine the whole time.
I can't answer if the pan hard for the SS will fit.
With the SS being lowered it may be shorter than standard panhard. I went adjustable when i swapped mine.
Check your stabilizer end links and bushings, they will go long before the trailing arm bushings, for after market go with Massive speed systems as they are adjustable for lifted and lowered trucks.
