crazyelvis3577
I just put new connectors on my 2003 Envoy XL that connect to the neutral safety switch or the NSBU. This was after my shifter wouldn't shift from park and I was trying to get it to move out of park by giggling the shifter pretty hard then it locked up again and I slammed the shifter back and forth needless to say it broke the shaft in the shifter but it will still allow me to shift gears (I disconnected the lock solenoid) So after doing all of this and then putting new connectors on the NSBU switch sonetimes the indicator lights (line under the gears) all work and then I can drive it and then shut it off and then every other one will work. What could be causing this? I have double check the wiring on the bew connectors. Could the NSBU be knocked out of adjustment or loose enough to move from time to time or maybe damaged insides from slamming the shifter back and forth? I cab still drive it and the engine and tranny all operate correctly. Anybody else have this happen? I've also heard that it can sonetimes be the ignition switch. Any help is appreciated!!
