gmcman
- Joined
- Dec 12, 2011
- Posts
- 4,685
Hope it's not a re-post but here's what works.
When you clean your TB generally you need to pull the wire harness but some may leave it attached. Either way, the PCM needs to re-establish the idle position after the gunk has been removed from the bore. This may or not be 100% accurate since the elapsed times are not set in stone.
Prior to the cleaning, it's best to unhook the NEG battery cable first. Disregard the cleaning if you only wish to perform the relearn.
Unhook NEG battery cable, remove harness from TB, perform cleaning.
Attach TB harness, after about 30 min of having the battery unhooked, re-attach NEG terminal.
Turn key to ON with all the dash lights on. DO NOT START AND DO NOT TOUCH GAS PEDAL. TB will perform series of noises during this time.
Leave key ON for about 5 minutes. DO NOT turn key off. DO NOT turn key off for the duration of the relearn
Start engine, DO NOT TOUCH GAS PEDAL, let idle for about 8-10 min.
Once engine has fully warmed, idle should settle around 600-625RPM. Generally under 650 RPM.
