Tool Talk
UPDATE: Friday, August 30th, 2024 @ 06-ish AM EST:
Since I'm held hostage to needing the added Leverage of the Longer 18" 3/8" Drive Ratchet and Sockets... it makes PERFECT sense to keep that Tool AND the other supporting Sockets ...AND... The Ryobi Replacement Bagging Blades inside of an "All-In-One" Carry Kit... So THIS Milwaukee Tool Tote Bag seems like the Right Choice...and at a Reduced Price of 24% Off for the $30.00 Cost:
When you "Pass The Rubicon" of being 3/4 of a Century in Age...You do NOT want to have to crawl around under an elevated Riding Electric Lawn Mower for any longer than necessary. I'm quite surprised and very pleased with the recent ease of performance of my MOJACK RELM Lift while Changing a FUBARed Blade recently... but I also wanted to enhance my ability to get the job done even QUICKER....Following the Suggestions of Archimedes...concerning having some MORE LEVERAGE.
So I ordered this NEIKO 18" Long 72 Tooth Reversing Ratchet (sporting an ALMOST Breaker Bar Handle Length) along with Three Variations of the Parkerized Impact Grade 15mm Sockets ... and they all just arrived. I would recommend this Tool Set in concert with the depicted SPECIAL BLADE HOLDER for anyone not inclined to having to play TWISTER while underneath their Lawn Mowers for this PITA Task any longer than required:
NOTE: Check Out that Strong Neodymium Magnetic Plug inside of the Shortest Socket!
RYOBIBLADECHANGETOOLS0.jpgRYOBIBLADECHANGETOOLS1.jpgRYOBIBLADECHANGETOOLS2.jpgRYOBIBLADECHANGETOOLS3.jpgRYOBIBLADECHANGETOOLS4.jpgRYOBIBLADECHANGETOOLS5.jpgRYOBIBLADESANDHOLDINGTOOL1.jpgRYOBIBLADESANDHOLDINGTOOL2.jpgRYOBIBLADESANDHOLDINGTOOL3.jpg
I've had one of these air jacks for 6 years now, and never had an issue with it until earlier today when it sprang a leak while lifting the front end of my EXT. I noticed the bag was tilted to one side, as it tends to do as the weight of the truck shifts, at full extension. I placed my hand near the bottom of the bag and could feel the air rushing out, so I assumed I ripped the seal or the bag itself. Lowered it back down, repositioned so the bag would be straight at its highest, and lifted again, that made it worse. :yikes:
I just went out to take things apart and have a look, and the problem showed itself almost immediately, after getting the 4 bolts out of the base. The air hose entering the bag had ripped at the fitting. And as soon as I lifted the metal shell from the bag, it tore off with zero resistance.
Got the compression fitting off, and what I assumed should be rubber, felt more like hard plastic. Had to use a utility knife to get the remnants off.
There was enough slack to make me think I could use the same hose, just insert the fitting into the freshly cut end that's already there. The line wouldn't stretch out to get over the fitting, and cracked instead, so I cut a quarter inch off, where it felt softer and tried again. Needed a little more slack due to the weight of the frame and the bag fighting me, and when I tugged just a little bit more, the whole damn thing came free. Line broke near the handle where it passes through the frame. :mad:
At least replacing the air line is about as simple and inexpensive as it gets, so that's a relief. Found a roll of .25" ID pneumatic tubing pretty quickly, but I don't need 32' of it!!! Everything else seems to be .25" OD, didn't think this would be that rare. 🤷‍♂️
Go to any big-truck repair shop, and ask to buy a length of 1/4" Synflex hose. Thinking Eaton makes it. We used a lot of it in various diameters when plumbing the compressed-air system on City Buses.
Great idea, ended up ordering the hose online last night, since it would be delivered today.
Reactions: mrrsm and Mooseman
Never considered one of these before. I can get one for $120CAD. That's cheaper than floor jacks.
Reactions: Blckshdw and mrrsm
My initial issue that got me looking at them, was my old Craftsman jack developing a leak where I needed to keep the handle locked at all times to try and prevent it. Even after replacing the seals, it still leaked.
Saw these offered by a bunch of sellers (on Ebay at the time) and after watching a video, figured it would be great to no longer need to pump a handle and start sweating before I even started on whatever the job was. Making height adjustments is quick and easy, especially from a kneeling position (I try to avoid repeatedly getting up and back down, my back and knees thank me for that)
While it does have some weight to it, they aren't as heavy as hydraulic jacks, so portability is a plus. Can't quite wheel them around as easy as floor jacks, and when they are laid flat, you're really sliding the thing around. So I use the small wooden furniture dollies for easy rolling. Only exception is when I need to lift the rear of the truck by the pumpkin, not enough clearance when it's on the dolly.
Reactions: Mooseman and mrrsm
I can't help but associate this Complete Snap-On OEM Diagnostic Compression Tool Kit that was offered over on eBay for an excellent price with the number of times that @Mooseman has reminded so many of us that whenever chasing down the Causes and Origins of Engine Mis-Fires:
"Don't Forget...to perform an In-Cylinder Compression Balance Test...TOO...":
So the new line has a thicker wall than the stuff I'm replacing, so that did not play nice with the fittings. I ended up taking a 3/8" bit and enlarging the fitting holes, but that still wasn't enough. Took a step bit and got it just large enough for the hose to pass through, with some effort.
Needed a little assistance fishing the hose up through the handle and through the opening to the valves, so grabbed the end of my wire snake, inserted it into the end of the hose to use as a guide. Worked like a charm.
With the hose routed, attached to the bag end, and bolted that together. Cut off the slack on the valve side, slipped the fitting on, and wrapped things up. Gave it a quick test under load, no hissing = job done! :2thumbsup:
If you want the benefits of having a REALLY BIG AND CRYSTAL CLEAR DMM with a "Brick Shape" Tilt Screen and TRUE 4,000 RMS with a Five Minute Back-Light Timer, Snap-On's Line of these DMMs start with "The Basic" (No Really...THAT is what they Call IT) and they'll Tear a $1,000.00 Bill RTF In Half...!
The other two in the Trio go over $1,000.00 to $1,500.00 for those Mechanics in need of DMMs capable of working on Hybrid and Electric Vehicle Problems. Luckily... I just picked THIS one up from eBay for *Two Benjamins*... and I thought,
"Jesus Palomino, Snap-On... THAT WAS JUST WAY TOO DAMNED MUCH MONEY...!"
But still... Dammit...!!! I Wanted One!
These Boys (and my Beef Cake Images) will give the Run Down on all of these DMMs and the Truth is...THEY REALLY ARE VERY EASY ON THESE OLD EYES:
Start Viewing at around 4:00 along in this one...
IMG_1317.JPGIMG_1340.JPGIMG_1339.JPGIMG_1322.JPGIMG_1332.JPGIMG_1330.JPGIMG_1329.JPGIMG_1342.JPGIMG_1338.JPGIMG_1328.JPGIMG_1325.JPGIMG_1320.JPGIMG_1318.JPG
EDIT: Saturday, January 25th, 2025
I did some further research and opted to include getting the Snap-On OEM Magnetic Nylon Support Hangar Strap and the Fluke Flavor of the Insulated Screw-On Style Red N Black Alligator Clips to work in concert with the Snap-On OEM Red & Black Pin Probes... and as soon as the Screen Saver Covers arrive and get applied... THAT will Complete This Digital DMM Kit!
A Brief Follow Up to the last Post... with some interesting "Tool Knowledge" offered by Snap-On concerning NOT using any "Classic" Incandescent Bulb Style Lighted Probes on Air Bags and in other circumstances... (View the Instruction Captures CLOSE UP for better details).
Note that the eBay Tool Vendor demonstrated his appreciation for selling me the Snap-On Probe by throwing in a Snap-On "Classic" Standard Blade -Magnetic Pocket Screw-Driver...Nice :>):
IMG_1403.JPGIMG_1405.JPGIMG_1406.JPGIMG_1409.JPGIMG_1411.JPGIMG_1415.JPGIMG_1416.JPGIMG_1418.JPG
PS... Don't LOSE that Black Plastic Point Protector... If you accidentally -=JAM or STAB=- yourself with THIS Very Sharp Thing...You'll Wish Your Mother Never Met Your Father!!!
I noted back in an Edit of Post #891 on January 16th, 2025 that I had ordered the Snap-On OEM Magnetic - S/S Hook Velcro Strap made specifically for this series of Snap-On "Brick" DMMs on January 25th, 2025.
Why it took all this time for the Seller to finally get around to shipping it so that it would arrive today, March 1st, 2025 is another mystery.
Nonetheless... It IS BNIB (Brand New In Box) and the Rubber Coated Magnet - Hanger really IS just as Strong as it was Advertised to be. So now ... This "Damned DMM Kit" is finally OEM COMPLETE!
With most of my "Ready Tools" sitting in a Large Collapsible Blue Roll-A-Round Wagon over at my Son's House... Recently, I found myself going to and fro amongst many seldom used tools around my Garage to work on my disabled Ryobi *RELM*.
I found this situation very unsatisfying and decided to populate my 10' X 14' Arrow Shed with two complete sets of Gear-Wrench 3/8" and 1/4" Drive High Quality Ratchets having all the requisite Shallow and Deep Sockets, very portable and close at hand in the advent of future repair needs in my back yard.
These very complete Metric & SAE (Clearly Labeled) Deep & Shallow components are NOT inexpensive, but for *Tool Lovers* everywhere, consider that there is just something Magical with their Chrome Quality and the Feel of the "Tear Drop" Ratcheting Action of 120 *Clicks*... there is almost no "Ratchet Resistance" at all and that makes for much better control in very tight places.
The Blow Molded Cases that house all of this *Stuff* is well made and has VERY Distinct and Secure Case Locks to avoid accidental opening and then... only being able to recover a fraction of the ones that roll away on the floor under the cabinets...never to be seen again. :>)
IMG_1890.JPGIMG_1903.JPGIMG_1900.JPGIMG_1897.JPGIMG_1896.JPGIMG_1895.JPGIMG_1894.JPGIMG_1893.JPGIMG_1892.JPGIMG_1891.JPG
Check out the Power Probe PPDRAW tool.
Reactions: movietvet
IMO, the cost of the tool is paid for by the ease of use and helping to keep the draw circuit live during the inspection process. My shop owner friend has one and loves it. He paid $270 for it on the Snap On truck but I got mine, brand new still wrapped in the box, from ebay shipped for $182.
No idea how it does the current draw via the OBD port, likely gets the info from the PCM or BCM.
That was my reaction as well until I found a Power Probe promo for this tool on YT; the answer is actually pretty simple. It has an internal battery that can source up to 10A for use as a maintainer/memory saver when disconnecting the battery as well as current measuring capability. Parasitic current is measured when sourcing power through the ODB with the battery disconnected. Clever!
Canada has no restriction for the vent however we did have a period where the vent was incorporated into the spout, reducing the size of the hole to allow gas out. Now we seem to have both, which is pointless unless it might allow more fuel out faster with the increased venting but still with the smaller hole. There are replacement spouts with no vent and bigger holes available.
images
And for those that are plagued with the completely missing vent, there are add-on vent kits available.
Reactions: northcreek
This is in reference to @movietvet 's post.
One thing about those old school Craftsmans, why didn't they have an 18mm? There's a 17/19mm wrench but no 18mm. I remember different tool sets that wouldn't have 18mm wrenches or sockets. GM are infamous for having 18mm all over the place, especially the brakes. I can't remember a time I've ever use a 19mm.
I wondered that myself. Maybe a 16mm/18mm is missing?
Heh... I have one of those blow-molded plastic Craftsman tool boxes for my socket set, and I always wondered why they didn't have a spot for an 18mm socket as well. Still have most of my first full socket set from the 70's in it, and had to buy an 18mm socket separately. Would be interested to know if there was an actual rationale behind it! :)
I purchased and am waiting for the NOS #42961 16mm/18mm double box end wrench. The price is raised from $330 to $350 and when the wrench arrives I will be posting another pic. It will be an 11 piece set then.
So it wasn't an anti 18mm conspiracy
:biggrin:
I didn't notice the missing wrench till was talked about here. Then I realized how many times I do use an 18mm on the vehicles I work on in my driveway.
stack
