twinners said:With the price of gas dropping so much in the winter just wondering if anyone switches to premium gas. would the extra octane help offset the mpg drop from the winter blend?
CaptainXL said:The solution would be to stock up and use summer gas for winter use. Then you would get better mileage.
muddy tires said:The gas would probably go bad before you used it all. Gas has a fairly short shelf life.
CaptainXL said:Propaganda. We store gasoline in tanks at the shop all the time out at the airport. Hydrocarbons have no shelf life if stored properly. Coleman white gas can be stored for 6 or more years in its container for example.
northcreek said:Perhaps the airport gas has no ethanol in it if you are talking AV gas.
Gasoline Expiration - Ethanol Blend Fuels Have a Short Shelf Life
Mark20 said:I noticed a drop in MPG on my trip home from NYC/LI this past week. I'll keep an eye on it but I suspect its the winter blend and less BTU per gallon.
Gasoline will still burn after it is stored for years but does not burn as well as fresh and I suspect leaves a lot more junk behind. A friend gave me an old gas can with 1.5 gallons of 10 or more year old gas in it. It smells more like varnish than gasoline. I burned some of it off in a tiki torch and have been mixing very small amounts with my leaf blower and soon my snow blower fuel. The gas I keep on hand for the power equipment and generator (which I may very well need this weekend) is treated with Sta-Bil as soon as I buy it. If their specs are to be believed, the gas will stay fresh for a year after mixing it in. I try to cycle it a more frequently than that.
northcreek said:From what I gather, old gas runs hotter and air cooled engines do not have the ability overcome it...Mike.
Mark20 said:I noticed a drop in MPG on my trip home from NYC/LI this past week. I'll keep an eye on it but I suspect its the winter blend and less BTU per gallon..
CaptainXL said:Your joking right? last years gas wouldn't be bad. Maybe 5 year old gas. I use old gas in my 2 cycle stuff all the time. The only way to melt a 2 stroke is to use the wrong oil mixture. That dipshit salesman doesn't know what old gas really is, nor what he is talking about.
CaptainXL said:We can debate this all day.
But the fact of the matter is that any type of gas will hold up if it is in a properly sealed container with no way for air to get to it. Oxygen and humidity both kill gas. We know that. Just store it properly. Preferably in a cool & dry location.
You can't blame most of this loss on winter gas. The colder a vehile is, the harder it is to move. Thick engine oil, cold transmission fluid, think rear end grease, thick front diff (if you have 4WD), all create horsepower loss problems. We don't have carbs any more, but we still have the requirement for a choke (on the old carbs, a choke cut off air, producing a richer mixture). Today's PCM just opens the injector for a longer period, resulting in a richer mixture.dmanns67 said:I have personally seen a drop from 18.5 mpg this summer to 16.5 this winter. I did not realize how much affect winter gas has on mpg until watching it closely last year. Not sure what other reason there would be to lose 2 mpg.
fuel economy during urban trips of less than 10 minutes, in cold weather with snowy road conditions can easily be 50 percent lower than operation of the same vehicle in warm weather with dry roads.
dmanns67 said:Good article and I see why moar of us have a 1-2 mpg loss during the winter months.
CaptainXL said:It's a little warmer where you are at. Up here in the great white north mileage drop more like 3-4 mpg. Ok I am not in Canada but we do see some nasty cold snaps from there all the time.
