Crank Balancer Puller and Install tools
BrownHP800
Does anyone have a nice used set of tools to pull and install a balancer on our 4.2 engines? I need to replace the front seal on my son's 2002 Trailblazer. I hate to buy new tools for something I will probably only ever use once.
Thanks
Have a look at my timing chain tensioner replacement write up. It will explain if you need the special Spent-Moore tool depending if you have the first design balancet or not. Only if you have the first design you need the tool. Otherwise, a normal 3 jaw puller should work. I said should because mine was a b!tch to remove.
It's listed in the 4.2 FAQ.
oeduardo67
